unable to telnet to my instance
msavazzi
I have configured the Root Credentials:
but I cannot change them,
I cannot access.
I've even tried the forgot password but what I get does not work
what I'm I doing wrong?
also on the page everything is locked
Yes this can make some confusion:-|
The Management Root is not the same as the Linux root - you need to find the root password created under the installation of your 3CX instance and log in with this root account
ouch! I followed the standard installation on... was it asked during intallation ?
Yep, you had to set the root PW for the Linux installation during the installation:)
Reactions: msavazzi
ok, so: me dummy!!!! now I have to guess what it could have been!
wish you the best of luck:-)
You chose the root password, right after you selected the language for your Keyboard..
Reactions: nub
AshleyStokes
