You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
I'm unable to upload the Call Flow App I created to 3CX. According to 3CX, there should be call flow apps under advanced tab
but on my end there's none. You can check on the 3CX system has already been upgraded to v20.
Platinum Partner
you need to go to intergrations and then go for Call Scripts:
and then the bottom option:
