Unifi Ubiquiti phones
simonog
I have now installed my first (and trial) 3cx system, and it is in the cloud.
Behind our router our current installation is all Ubiquiti desk phones, which we used with our previous pbx. They are not one of the auto-provision phones in the 3cx list.
Has anyone found a simple way to provision manually phones which are not on the list? while having little experience with 3cx specifically, i have configured my own VOIP systems for some years so am familiar wiht the principles.
Any guidance eg pointing me to any documentation for this would be fantastic - i have done various searches to no avail.
Do you run 3CX SBC or did the phones work without?
Mine all just worked without the SBC, but I'm only running 2 remotely at different sites and not a heavy load on them.
I was actually evaluating those phones, but decided against it as Ubiquiti seems to be moving away from supporting third party voip platforms since releasing their own.
You definitely want the Unifi Voip controller, and will have to program each extension manually into it. The nice thing is though, after doing so you can then push that extension to handsets as needed.
You also definitely want an SBC setup in the local lan to point the phones to.
Good luck, and I hope your experience with the phones is better than mine!
PS, Check out the Yealink T56A. Similar to the UVP-Executive
ajjuds
