Unregister Etisalat SIP Trunk / UAE With 3CX
Ali Mohammad
Hello all,
My telecome provider etisalat / UAE has installed a sip trunk in my office. i use 3CX.
the trunk works perfectly with xlite however i cant seem to be able to register using 3CX
these are the settings for xlite.
User ID: +9714XXXXXXX
Password: Password
Domain Name: YYYY.etisalat.ae
Proxy Address: ZZZZZZZ.etisalat.ae
Authorization Name: [email protected]
inside topology:
range of ports used for signaling :5060-5061
firewall traversal: auto
i would like to get some help if possible from someone to map the Xlite configuration to a proper 3CX configuration.
What is the error message you are facing.
How did you set the trunk in 3CX ? from generic template ?
We found that the sip trunk will not register without the authorization name, i tried to use the the id and the authorization name at the username but the trunk keep showing failed to register and if i tried to use authentication ad ip address it will show green on 3cx but can’t receive or make calls
Have you configured inbound and outbound route?
Hello all,
Password: Password
inside topology:
Hi Ali,
have you got a solution for the SIP Trunk? please reply
youwillbrun
