Update 4 Final: Affordable Call Transcription with 3CX AI
MichaelB_3CX
3CX Team
Staff member
3CX Support
Cost-effective call transcription powered by 3CX AI.​
Update 4 introduces groundbreaking 3CX AI, to make transcription more affordable. Unlike external services such as OpenAI or Google, 3CX AI comes at a better price. Enterprise users can access 3CX AI transcription free of charge for the remainder of 2024. This trial period he...
It wasn't working for me just as an hour ago.
Hi guys
what do we do if 3CX AI is still transcribing in welsh?
Will we be able to use this drop down to select language at some point?
:D
Hi guys
:D
The computer wants you to learn to speak Welsh!
The CFD will be updated to implement transcription with OPEN AI and 3CX ?
Free voicemail transcript are only for ENT version and until the end of this year ?
Reactions: MayurPatel
I am looking for clarification on voicemail transcription (not call transcription): Is voicemail transcription free on PRO licenses, or Enterprise only?
As of now on my test PRO licensed 3CX instance that is on update 4, there is no "3CX" option in the Transcription Engine dropdown, and voicemails are not being transcribed.
OK the question has been posted a few times but here it goes
A. Google Transcription is part of PRO and has been part of v18. You can transcribe voice mail and whatever you want as long as you use Google remote storage. This is a requirement of the Google transcription API
B. On Enterprise, we are going to make voice mail transcription using 3CX AI free. For now call transcription is free for testing purposes. You can also use OpenAI if you like if you have the Enterprise edition. Yes OpenAI integration requires enterprise edition.
Nick, thank you for the reply. Reading through all the other posts it gets a bit convoluted and as things change from alpha to production, I was looking for the definitive answer.
Reactions: Greg_G and N_G
Yes of course no problem at all...... And its true that sometimes we are not up to date with some of our communication what is required and what has changed etc. Thanks for the headsup and understanding.
We dont have any plans to update the CFD quite honestly. We are going to invest in the call flow scripts - more samples and hopefully in time we might try to use AI to make it easier to create more scripts.
Using the web api in update 4 you can already integrate openAI quite easily. We can definitely provide some samples for that - maybe one that answers a call and responds in voice....
A sample for this would be great!
I just installed update 4 on a Pro system that was using OpenAI for voicemail transcription, OpenAI is no longer available as a transcription engine on that instance. Was this by design and not in the release announcement or is this a bug?
I believe OpenAI is only allowed on ENT licenses and is enforced now. We have ENT and see OpenAI with no issues.
That would have been nice to see in the release notes! I have clients relying on that and have no desire to store their voicemail in google storage to unlock that transcription.
Reactions: SBuckley
Not sure how you run things, but normally for our systems we install updates and test before installing on a live system. That way can test and ensure everything tests out well. I do recall seeing though the ENT license requirements in blog post around transcription. I believe it was stated the initial OpenAI transcription, although seen would eventually need an ENT license to continue using. I can tell you it works fine with the ENT license.
Good to know about the OpenAI! I have a Pro license and have loved it since we installed 20 a couple months ago. I don't want to lose it.
If Enterprise is free for the rest of the year with new 3CX transcription, what does Pro get?
Update: I was able to roll back to update 3 with an APT command in the host OS, OpenAI transcription restored!
I'm sure this is something that is not recommended but it worked for me and I haven't seen any ill effects.
Reactions: EmmettsIT
I am disappointed to read that the CFD will not be updated. It works very well and is a good GUI. The one feature I was hoping for was the ability for the CFD to read Department Hours rather than having to add in the C# script every time a CFD is changed.
I have Pro and just updated. Where is the free voicemail transcription settings? I know Open AI is gone, but my only option is Transcription is Google.
Jeremy Hofex
