Update history should be documented.
ZenMasta
There should be a section in the updates tab underneath available updates, that shows update history. Name installed date, etc.
Reactions: SteveITS
Feature requests can only be submitted by higher tier partners.
Id try looking in the ideas section for this and upvoting, or ask a higher tier partner to post on your behalf.
You could turn on email notifications for when an update is available and when an update is applied, then cross-reference this.
https://www.3cx.com/blog/change-log/phone-system-change-log-v20/
Just a quick mention, the Audit Log covers this to an extend (for as long as it's not purged/auto):
And emails are sent every time the PBX updates itself.
/dev/simon
