The cost for the upgrade (difference between the two levels) will be prorated based on the remaining days to your license.Hi,
I want to know that if upgrade 3CX 16SC PRO To 32SC ENT with the new partner, is there upgrade cost addition to 32SC ENT?
Can I upgrade by myself or through partner only?
Thanks for your information!
Thanks for your reply.You can buy direct, or via a partner. Usually it will be the same price, although some partners (like us) do pass some of the margin to customers.
Not sure what "old license type" you might have. Perpetual licenses have been gone for years.Thanks for your reply.
In my case, I'm using the old license type and if I renew my license, new partner said I cannot renew "have to buy new license type with appropriate maximum users/ext / have to set-up from scratch".
If upgrade, I have to pay for the upgrade fee (32SC ENT + upgrade fee).
Want to know that this upgrade fee is in the 3CX policy or just partner service fee? Because this fee is 1/3 of the license price.![]()
HI Steve,@PCHI If one clicks Upgrade in the portal, it adds "hosted by 3CX" by default...perhaps this partner is seeing that? Just uncheck that...
When clicking Upgrade, by default it leaves the same license level and size but adds Hosted automatically and you cannot uncheck it.@PCHI If one clicks Upgrade in the portal, it adds "hosted by 3CX" by default...perhaps this partner is seeing that? Just uncheck that...
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
