Upgrade to V18 and Get One Year Free Hosting
Natassia Allery
Head of Customer Support
Platinum Partner
Calling all 3CX customers ...upgrade to Version 18 and you can benefit from an entire year\'s FREE hosting with 3CX! V18 has many advantages over older versions, including new Teams integration, a new Web and desktop client, and a much better mobile experience. Existing V18 customers are also eligible to receive the first year hosting free when swi...
My current V16 license has 8SC (license expires next year), when upgraded to V18, do I still get 8SC?
What is the best procedure to transfer to 3CX hosting?
Can I get Console Restrictions in 3CX Hosting?
Reactions: DimitrisL_3CX
Yes you should still get 8SC. Otherwise, upgrading to a Std or Pro 8SC is extremely cheap.
No you cannot use console restrictions on Hosted.
Hi @tony28
The procedure is simple.
You can reinstall your subscription and choose "Hosted by 3CX" option and click "Next"
On the next step you can chose to restore your backup (backup size must be less than 1024MB).
If your backup size is more than 1024MB you can always restore it after the installation finish.
For more information you can always read the manual (https://www.3cx.com/docs/switch-hosted-pbx/) on how to migrate.
Reactions: NikosT_3CX
@Dimitris_3CX
Do you upgrade from V16 to V18 then move to 3CX hosting or
Move v16 to 3CX hosting then upgrade to V18?
Should the backup include license key?
@tony28 you can have your backup from v16 latest service pack, upload it to the 3cx Deployment Wizard in your portal and start the hosting with 3cx.
The Deployment Wizard will convert your backup and the installation will be on v18 with your data.
Yes backup must have subscription key and FQDN or else you will not be able to upload it.
Only v18 is deployed on our hosting platform!!
@NikosT_3CX since 3CX hosting have no access to License Key Tab (and replace license key function),
-if I need to downgrade from 8SC to 4SC with current license, what do I need to do, if I cannot change license?
-if I need to upgrade from 4SC to 8SC with current license, what do I need to do?
@tony28
Key replacement is not possible on a Hosted by 3CX instance.
>> you may login to your portal ( https://portal.3cx.com ) and open a chat with our Customers Service Team.
Or you may drop them an email " [email protected] " and the Team will assist you directly on that.
>> You just login to your portal, select your key and click Upgrade, that's it.
Reactions: jed and Evolute IT
Jeremy Hofex
