Upgrade to v18
uithollend
New User
After upgrading to v18 my admin menu is incomplete and I cannot access ring groups, assistent, etc.
What can be wrong?
Thanks in advance.
Greetings,
Robin
What can be wrong?
Thanks in advance.
Greetings,
Robin
You are probably not the main admin (the A upper-right), so your extension has limited rights because they changed the granularity of those management rights.
Reactions: ChrisC_3CX
Ring groups are inside users menu.
And others menus are in different places
User "groups" are in the Users menu.
Ring Groups still have their own menu.
I think Frederick is spot on, the following user rights would actually give you the access apparent in your screenshot:
That said, do check if you are indeed logged in as an extension(Check upper right corner) and if yes, simply logout and login with the main admin account.
Nari
