Upgraded to Pro Edition but don't see Server Side Integration
Markyg
My understanding is I need Server Side Integration to set up Zoho CRM to use 3CX.
Reviewing the available information I upgraded to the Pro Ed however this has not resulted in Server Side Integration showing up.
Is there something else I need to do?
Mark
Try logging out and in, then refresh using Ctrl Shift R to clear the cache.
Thanks for the suggestion. I also closed down Chrome and restarted - unfortunately no luck :(
Also opened 3CX in Edge - which has never before run 3CX...still no luck.
Have you tried to restart the 3CX server ?
lastshadow
