Upgrading from 12.5 Physical to 15.5 Hyper-V VM
kforfa
We had a previous attempt to upgrade that failed. We have since decided to use a VM instead of another physical server. We are planning on exporting the SSL cert from the previous "new" physical server and then importing that SSL to our new VM server. Just looking for conformation that when backing up 12.5 (SP2), not to select the last option (Backup SSL...FQDN). Also, did anyone have any lessons learned they can share about moving and upgrading at the same time.
Thanks!!
cur_cb
