Upgrading from v18 U2 to v18 U7
leo212
I'm trying to update my system to the last version but in management console under update i get only:
18.0 Update 2 Web Client Update
I have been going through the documentation but did not find a straight way to upgrade from v18 U2 to v18 U7.
This is 3CX system installed on Windows
Is the redeployment mandatory?
Best regards
Leo
Hi @GeorgeP_3CX ,
Thank you very much for the response.
Going further down after downloading the installer do i need to uninstall the current system or just run the installer and no need for further action?
Best Regards
Leo
The current Phone System will need to be uninstalled first. You cannot install a new 3CX Phone System if there is one already installed on the machine.
aha ok so redeployment is a must, thank you very much for the support
DejanMDS
