Solved URGENT Install version 15.5
imagemaster
Version 16 installed automatically this morning. I have tried to reinstall 15.5 and restore from backup but every time I install 3cx it installs version 16. How can I force version 15.5 to install. Call Flow is broken and we need to get back.
So many people don't understand the perks of disabling auto-update. You're not alone mate.
I need the procedure to install version 15.5
Reactions: Nick W and nub
Thank you! That was the right track. For correct reference the following command is what finally worked:
apt-get install 3cxpbx=15.5.15502.6
Make sure to first remove the current version with the following:
apt-get remove --purge 3cxpbx
Reactions: YiannisH_3CX
GP Concepts
