Solved Usage of Operator Number ( 0 )
Tin Nwe Win
Gold Partner
Can I use the extension number as an operator Number ( 0 ) even though we are using the 4 digits length.
Can you please kindly how can I configure that.
I would like to call the internal extension number that will be the extension number ( 0 ).
I am not clear about the link that you mentioned.
Could you please kindly assist with that.
Go to Settings > Network > FQDN and turn this on
Specify the SIP ID under your extension > Options
Reactions: ChrisC_3CX
Under options for the user, enter 0 as SIP ID
Under Settings - Network Settings - FQDN, enable 'Allow calls from/to external SIP URLS
@kieferschild Now I got it.. Thank you very much for your support.
Bluebox Global
