Use AI Tools to Build 3CX CRM XML Templates
Kevin Attard Compagno
Staff member
3CX Support
Simplify creation of 3CX XML templates with our AI Prompt.​
We’ve prepared an AI Prompt for use with an AI Chat agent, designed to help create a CRM XML template for your CRM. It has been built and tested specifically using the Cursor application, using Claude Sonnet 4.6 as the model. You can download the CRM_Prompt.md file to...
r.dahal
