Use Extension for Specific Outbound
nareach
Forum User
I have 14 extension and i have 2 outbound route with 4 zap trunk.
and i want my 7 extensions use with first outbound
and rest 7 extensions use with second outbound.
thanks.
There are two ways to accomplish that
1- On your outbound route settings, you should add the rule with the CallerID numbers that are allowed to use that route.
2- Use Custom context modules where you can allow/deny routes to groups of extensions.
As you have only 14 extensions the simplest method is #1.
Hope it helps!
Please explain me clearly and give me some example.
