Use main trunk number as outgoing call number
miirconcepts
Hey there,
first - I already appreciate any help, because I've tried everything that I can think of.
We have one main phone in the office, that all calls without an extension go to, so the main trunk number is associated with it - this works perfectly fine. The issue is, that when we make a call from the main phone, it always adds the extension number which it should not.
My question is - how can I realize it in a way, that when I call anyone using this main phone, it also uses the main number without extension?
I've already set it up in a way, where the outgoing number is set to the main trunk number, but it still adds the extension to it.
Thank you for any help!!
Check your settings in your VoIP provider configuration under options and Caller ID control
Reactions: miirconcepts
Isuru Eranga
