Solved Used "Self Host" option to transition to Azure, lost all configuration data
smartinet
I used the Self Host option to migrate from 3CX Hosted to Azure, however none of my data has come across.
The backups were done locally on the 3CX hosted instance, but now I can no longer access it as the FQDN is pointing to the new Azure instance - which is effectively blank.
How can I get access back to the 3CX hosted instance to get my config back or obtain the backup?
I note there were no warnings or procedures mentioned when using this function, and it looked nothing like the documentation here: https://www.3cx.com/docs/switch-hosted-pbx/
@smartinet as I can see you have also opened a ticket with the Hosting Team about the same exact topic so lets stick with the ticket.
Ok, sorry wasn't sure where to turn on this one as I was in a panic.
I found the hosting email address after posting this.
@smartinet no worries, you already got a response in the ticket so i am closing this thread :)
Kayla Norris
