Solved User is not able to make external calls
Brock_4118
Hi all,
I have very peculiar problem, one of the extension in my 3CX is not able to make outbound calls. he can receive calls from outside & also able to call internally but cant make outbound calls.
previously he was facing issue that he wasn't receiving incoming calls but was able to make outbound calls so i add him all appropriate group & queues so he was able to receive but then
can't make outbound.
Plz suggest me where should i check now.
Thanks & regards.
hi,
try to check this in extension options
13798
Hi aws2p,
All the settings are fine as shown in your screenshot.
any other place to look.
Make sure that your outbound rules allow this user to make outbound calls. You can also check your activity log and see why the user cannot make outbound calls.
Hi YiannisH,
Outbound rules is same for everyone,below is the log i got & when i call it says call number does not exist,
Call or Registration to 0405847@(Ln.10000@Springcom Line - 0884665) has failed. 0.0.0.0 replied: 604 Does not exist anywhere; from IP:0.0.0.0:5060
Does this EXT have an outbound caller ID set?
  • Love
Reactions: Brock_4118
Hi Kieferschild,
Thanks mate, outbound caller ID was there but 0 wasn't mentioned that's why call was not going through.
I just added the 0 before the number & it worked :)
Thanks a lot mate & everyone else.
Well done
  • Love
Kayla Norris
