User not register
PeteOJ
Forum User
hello
i re use an old user extension for a new employee
when i go in 3cx portal i see the user as not register what does that mean ?
plus in my client i see the use as busy but she's not
Can you please enable the notifications as per forum post here and check again?
hello i dont have version 20
when i open the app on my phone or pc i see few users not in the list and if i search the extension i see them not registered
not sure why.
So if the users using 3CX Weblcient and have their application exited/shut down, you wont see the presence.
In the webclient you can enabled to see unregistered users too if this is your goal, this can be configured :
i have the desktop client version 18 how can i see the unregistered ?
also i have a user that have phone on her desk and we see her as unregistered
ok i see them now i found the setting in the app but why they are unregistered ?
If they exit the application the application will not be registered.
If its a deskphone, there can be many reasons there, let's say blacklisted IP because of the wrong credentials, networking issues etc.
where i can see if the phone ip is black listed ?
she can call and receive call anyway but in the app i see it un registered
Its under the dashboard >> pbx status >> Blacklisted IPs
but in my case it's a user inside the office
So if your PBX and phone in the same local network, the local IPs can also be blacklisted.
ok but it's not
Try to open from another machine, do you see it? If he use it outside the network still the same?
It can be also a restriction internally.
neshima
