V16 Browser extension direct link won't properly activate
jmatano
Platinum Partner
I know the ongoing thread was closed, but there is another issue looming. The direct link to the old extension was posted, https://chrome.google.com/webstore/detail/3cx/dijllljhgnommpcoogbfcnadmnleeook/related
However after you install it, when you activate it in the web client, the extension doesn't actually activate and it stays grey yet the webclient activate button goes away. We really need a workaround for this, as support stated June 2022 for it to be decommissioned.
Hello @jmatano ,
This extension it requires v18 U2 PBX in order to work per description.
For v16 as per main blog post thread suggests, the options are either WebClient or use the old Windows client that is still supported
Yikes, that just killed all click to dial for V16 users inside of Chrome, unless I am missing something? That's sort of a major feature to ditch for a version that is supposed to be supported for another 7 months.
Reactions: Fabrizio Sala
Will the old extension in Edge and V16 of 3cx work for now or is it also scheduled for replacement?
Edge plugin will follow suit as the Chome one, if it hasn't already by the time I am writing this.
I will lock this thread though and any and all queries about this can be posted here:
https://www.3cx.com/community/threads/update-2-final-search-across-contacts-and-team-members.86335/
As there is quite a bit of information in this thread already, have a read through it as you may get already the answer you are looking for.
megalmazan
