Solved v16 call reports
supportOBT
what happened to the call reports? They dont show up on the menu anymore, only call logs. Also, when i go into extensions, it will not let me check call reports as it is greyed out.
Really? Is their a way to downgrade? Reports worked fine for me in the last version. I can't believe they would remove the features. I've paid for the software for a year.
If you pad for the software, and it is a commerical version you should be updated to Pro version. Have you tried to refresh you license with the management console
No, I can try now. will that interupt service. I am looking at it now and it states the following..
Product: Professional Annual
3cx Phone system pro edition features: Yes
but i notice on the dashboard it says Standard Annual. I will try to refresh license after business hours.
You may also have to restart the services.
i have refreshed the license and the reports are back now.
Glad to see the issue has been resolved and thank you for updating the thread with your solution. For future reference refreshing your licence details does not disrupt services.
GP Concepts
