V18 - Admin Access
Matt Larter
New User
Hello all,
We have recently changed over to V18 and I;ve just logged into the management console to find that I no longer have the rights for "Phone System Administration (Can manage inbound rules, digital receptionists, ring groups, queues, contacts and system music on hold)". I am the only admin and have the only admin login to the system so I dont understand how this has happened.
Can anyone shed some light on this please?
Thanks.
You definitely are not the only admin if you login with your extension.
You'll need to use the main admin to reconfigure your rights.
Ok understood. Is there a way of finding out what admin accounts are on the system?
The main admin is only one. If you know the username, you can enter it a couple times with a bad password and a "forgot password" link should appear.
Otherwise, if you cannot see other extensions, then you won't be able to see other admins (if extensions have the rights.)
Reactions: bitn2
you have a main admin account, that is not the same as the extension.
Thanks all, I have managed to sort this. I had no idea that another admin account even existed!
arming
