- Joined
- Jun 6, 2006
- Messages
- 4,869
- Reaction score
- 9,372
Great - we’ve got 18A3 deployed with some rPIs running the old version without any issues; just wanted to check we were testing the correct thing.@AlanRamsay Its the same one there is now, there is no specific v18 one....
This usually happens when the machine does not have internet access, because it tries to get information from the repositories online and it fails, so it just prompts you to login.Hello,
i tried to install the v18 Alpha 3 from the ISO image, but if im ready with the debian setup and the system reboot is done, there is no 3cx installation, just a login command. Any idee what to do ?
Just an update, this shall be fixed by the time V18 is final.I upgraded our test instance from Alpha 2 to Alpha 3, and then enabled 365 User sync. Below is a screen shot of what happened to existing users mobile and outbound caller id fields. PM me if you need any more details.
Hi!I stumbled upon this on the Snom website:
With the version 18, 3CX decided to end the support for specific TLS v1.2 cipher suites, and to simplify the DNS configuration with its DNS Helper feature. These changes prevent the M700 - a product that has been declared end of sales/support (EOS) June 2020, after 6 successful years in the market by us - to be auto-provisioned and to register to the 3CX SIP server when updated to V18.
The M700 is EOS and there will be no further firmware updates.
While manual provisioning is an option, although not supported or recommended, you could do it, and already configured devices should continue to work with issues, HOWEVER, the Phonebook will stop being updated and any changes you make in the management console will not be passed onto the device.We host all our 3CX servers in our private cloud for our customers does this mean our customers can trow away all their M700 dects. Our can we manualy connect the M700 to the 3CX cloud server without provisioning?
I have just found out that snom has issued a rebate for the M700 for users of 3CX, where you get the M900 as a replacement at some discount. What you need to do is send an email to [email protected] with subject "M700 Exchange" and briefly explain the situation. This offer is exclusive to 3CX partners and is valid until 31/05/2021.I stumbled upon this on the Snom website:
Local installations
The only way an M700 base station can be provisioned and registered on 3CX V18 is to switch off the DNS Helper feature, and use the provisioning method Local LAN. Any other provisioning method will request an HTTPs connecting to the 3CX server and therefore fail.
So people are using Citrix and Terminal Services but not Active Directory according to you? Didnt even know that was possible but definitely there are not a lot of those companies. Use the Active Directory SSO.@Nick Galea I agree with @MannyL about the need for 3CX to support the SAML Standard. Don't be too focused on the cost; many of us are using products (Such as Horizon with VMWare Workspace ONE Access or Citrix with Citrix Workspace) that bundles solutions relying on SAML to offer a true SSO experience for the user (going from VDI to Terminal Services but allowing SSO to Office365, Salesforge and many many others)
That could be great for anyone that wants to deploy 3CX to a large userbase by simply publishing the app in the company portal (i.e. Workspace ONE) relying on said portal for the authentication security (2FA, geolocation or any rules the administrator wants to enforce!).
I would be glad to open an idea about SAML, but I'm not allowed!
SAML is easy to support and doesn't require you to test with multiple providers. You can just implement it and make it "it's there but we can't help much".@Giuseppe Ravasio Then i dont understand your point. We fully support 365 and Azure AD for SSO so these customers are fully supported by our choice for SSO
@Nick Galea, as @Frederick Marcoux said O365 and GSuite are very specific (I would add very simple and very closed) and they are directly used mainly by SMB (more small than medium to be honest).@Giuseppe Ravasio Then i dont understand your point. We fully support 365 and Azure AD for SSO so these customers are fully supported by our choice for SSO
Agree, I used to work for one of the largest VAR's in the US as a pre-sales solutions architect. I ran into many customers (usually startups) that didn't have AD/LDAP at all. They usually relied fully on cloud first solutions like Okta or Idaptive for Idp. Usually they had a mindset of Microsoft is evil and would avoid there solutions too. But at the same time with working with those customers I didn't find one startup that wasn't using O365 or Gsuite. Not to say the world is only on those two solutions... With some of the political climate in the US I've known some people to be interested in dropping certain cloud things as well.SAML is easy to support and doesn't require you to test with multiple providers. You can just implement it and make it "it's there but we can't help much".
SAML can allow any type of SSO, whereas O365 and GSuite are pretty much very specific and may not be used by a company. I've seen that a lot too.
In your experience of this 80% how many ends up having O365/M365 license with Teams included for "free"?I'd say it's not a bad idea to look at a way to more so integrate directly into an Idp's eco-system as a ready setup app. But in the world of 80/20 efficiencies can 3cx capture 80% of the SSO userbase for there product on the way they want to do it at 20% or less of the effort? I've noticed most SaaS offerings are going the way of adding a button for Gsuite/Microsoft and doing it the easy way vs building some complex SAML Idp mechanism since that is the majority of the market for business authentication.
Good point Giuseppe. I've worked for a company where I had teams and just my cell phone for 5 years.In your experience of this 80% how many ends up having O365/M365 license with Teams included for "free"?
In my experience they are more than 50% and growing; thus they probably will never be interested in 3CX.
On the other side, the 20% cannot even deploy Teams at all.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
