V18 fresh install, no upstream Debian repos?
yetopen
Hi.
We just made a fresh clean install of V18 (still have to finish setup), I just noted the system doesn't use Debian repositories but only 3CX ones. /etc/apt/sources.list only contains:
Code:
deb [arch=amd64 by-hash=yes signed-by=/usr/share/keyrings/3cx-archive-keyring.gpg] http://repo.3cx.com/debian/1803 buster main
deb [arch=amd64 by-hash=yes signed-by=/usr/share/keyrings/3cx-archive-keyring.gpg] http://repo.3cx.com/debian-security/1803 buster main
I was trying to install tmux but fails:
Code:
The following packages have unmet dependencies:
 tmux : Depends: libevent-2.1-6 (>= 2.1.8-stable) but it is not installable
E: Unable to correct problems, you have held broken packages.
Is this intended? Thanks
Yes.
Then repos are broken :)
No, you should not be installing any other applications on the 3CX server,
This is done, so that when it comes to updates / upgrades there will install correctly.
You are both correct.
a) Third party tools shouldn't be installed on a 3CX server
b) tmux is allowed and is available in our repository, however a dependency is indeed missing. The issue will be addressed in the next repository update.
Silent_Guru
