V18 Inbound Rule Issue
jcostlow
Gold Partner
  • 3CX Version: 18.0.1608
  • Server OS: Debian 10
  • Is the 3CX Server Hosted and where: Locally installed
  • IP Phone Make/Model/Firmware: N/A all app
  • Provisioning Method: N/A
  • Trunk Provider or Gateway Make/Model: Telnyx
I have a test system that has been running fine. I noticed when using it to test faxing that it never came through. Upon looking into it the number I have assigned under inbound rules to go to the fax server is going to the IVR.
The "main" number is set to go to the IVR under the SIP trunk settings and inbound rule has this number going to fax. I am not sure why it isn't following that rule.
SIP Trunk
Inbound Rule
Try putting the DIDs as *(10digits) instead of E164. It did the trick for me but I think there's a bug on either Telnyx or the template that makes the SIP INVITE come in as E164 without the +. However, even that in the rules didn't seem to work for me.
As it's an Alpha tho, I expect this to be fixed by either party before the official release.
Reactions: jcostlow
That did the trick, thanks. I thought I had it working with the numbers in E164 previously. I do see the call coming in 11 digit instead when running the capture.
This is my test box for the alpha to see all the changes and using Telnyx so I can just prepay the account for testing.
Yeah, it used to work with E164 but for some reason it doesn't anymore. I use SIP TLS, maybe that is related to it.
My guess it's that it is a Telnyx issue.
zipman
