Solved v18 Update 3 Web Client on ChromeOS Pixel Slate
edfosho
We have upgraded our system to v18 Update 3, but on my Google Pixel Slate (running ChromeOS 98) the Web Client is zoomed in, or displayed as if I have a larger monitor than I have - either the left, right, or both sides are cut off (and I can't scroll to them either).
No idea why this is, it's working on other up-to-date Chrome OS devices (tested with a colleague).
Any ideas why this may be, and is there a fix?
Hi @edfosho,
I'm assuming that pinching to zoom out doesn't work?
Can you try and hit Ctrl + 0?
Just managed to get a screenshot if it helps.
You can see the vertical scroll on the right, but nothing for the horizontal at the bottom. I can briefly see the left-hand menu if I use a ChromeOS mouse track gesture to see it, but it then defaults back straight away. I can't see the top left options at all.
Hi @edfosho,
Can you log in to the WebClient rather than the App and see if it's resizable?
That is the web client (sorry, I cropped off the top due to the FQDN). Here it is again:
Note, I'm running stable channel of ChromeOS, and I have the '3CX Click2Call (BETA)' plugin installed.
Wait...!
It's now working. I uninstalled a plugin (that I forgot about) that re-sized windows at my FQDN, depending on whether the webclient or Management Console was in use.
Sorry for taking up your time!
Great to hear @edfosho! Feel free to open a new thread if you require anything else!
megalmazan
