V20 : call in progress information ?
sitvca
Hello
Why in dashboard there is no information about call in progress ?
before migration to v20 we see call in progress like 15/64 for exemple.
is it possible to add this ?
Thanks for all.
This was removed.
you'll need to look at the panel view to see active calls.
According to 3CX, keeping that counter updated took a surprisingly large amount of resources to track and display this information. We once had a "3CX Call Counter" tool as well, but came to the same conclusion -- to keep the information up-to-date in real-time was very computationally expensive. This counter has been removed by 3CX and we are told it will not be returning in the future.
While I found it quite useful for a quick “can I do ___ without dropping a call” check, to “yes and” this, I’ve run into other situations where someone, say, leaves their router dashboard open all day, with a dozen widgets open, then wonders why CPU usage is not low and the web process is logging so much. So, Panel it is…much less painful if we already have the web client open in v20.
Reactions: Nathan@Voxtelesys
This feature comes back in v20u1
Indeed, this option will be back in Update 1.
tom.walker@blackcountryra
