v20 - Can't save Call Flow Selection in Department Destinations
EvolveServices
SOHO User
Hello there,
I have recently updated to v20, and although the upgrade worked well for already configured trunks, I am having trouble adding one. The problem I run into when selecting the routing destinations to a call flow app is that it does not save the Call Flow I choose. Once I select the Call Flow app and I save changes, upon re-entering the settings, the field is blank again. This seems to be a bug in the new update and is preventing me from configuring the call routes properly.
Reactions: nikolascx and jed
I'm able to reproduce when the CFD app has not an extension set. It works fine when the CFD app has an extension assigned. I will report this internally, thanks.
Reactions: jed and Evolute IT
Yup got the same thing with a name-only CFD.
Reactions: jed and edossantos
I appreciate you looking into this. Thanks!
Reactions: jed
This will be fixed in the final release of v20, thanks for reporting.
Reactions: jed
Jeff_MKC
