V20 Fax to Email
andybma
Gold Partner
Hi there. In V18 when creating a trunk you had the option to route to fax and enter an extension that had an attached email address. That option appears to be missing or not yet implemented in V20 or just the process has changed to the point where i cant find it. Has anyone yet implemented fax to email on an user in V20 that wasnt an existing configuration from an upgrade from v18?
Thanks.
You can set up a fax to email via admin console > Advanced > Fax sever section, only one can be added at the moment but thre will be more options for multiple fax to email in upcoming updates.
tom.walker@blackcountryra
