V20 Missing Features and V18 Extension
zebis
Hello All,
With V20 still lacking features in V18, is there an opportunity for continued v18 functionality beyond 2024 until v20 has matured?
One item that sparks this question is the removal of granular scheduled reports within 3CX. 3CX v20's scheduled reporting feature only supports a single global run time for all reports, while v18 provides complete granular control, establishing the power to set run times per report. In one environment supported by v18, 15 simple scheduled reports are fired each day at specific times, and this capability has been removed with v20.
Another reporting item removed from 3CX in v20 is the ability to focus reports to extension ranges within a department. In v20, the reporting system is limited to specifying the department, losing the option to filter to extension ranges.
3rd party systems explicitly advertised to address this shortcoming of v20 can be licensed; however, for simple reports, the back-end and additional capabilities that need to be licensed are a bit overkill.
With 3CX pushing back the restoration of granular scheduled reporting until after 2024, would 3CX be willing to enable v18 to continue functioning past 2024 to avoid environments enduring a below lateral move and losing functionality with the goal that these environments would switch to v20 when it's more mature and workflow tools wouldn't be lost?
Thank you!
Reactions: PhoneMan123
The cut off date is not a hard cut off date. We will be stopping the support of Version 18 at this point.
We will be releasing the new reporting engine in early 2025 https://www.3cx.com/blog/releases/call-reporting-updates-2025/
Your Version 18 PBXs will keep working past this date, but at some point certain services like PUSH will stop working and at some point it wont be able to activate.
Version 20 is at a mature stage, just one thing is left and this is being addressed.
This topic has been beaten upon ad nauseum and there are already many threads about this.
Hello NicholasP,
Thank you for the quick reply; I appreciate your time. The information you provided and your perspective is helpful. Is it known if Android and IOS PUSH and activation will work through the release date of the new reporting engine or would waiting for the reporting engine before changing to v20 risk an outage?
Also, on the topic of features not yet available in v20, is it known if the ability to set extensions to forward to free-form strings will be restored? For example, in v18 it's possible for an extension to forward to a conference room by "<conference ext>*<conference id>" or parking space by "SP<x>" and, in v20, free-form strings are limited to being processed only as an external target.
Thank you!
LewisJC
