Solved v20 Office Hours
RobColver
Is it true that, in v20, the only way to apply different office hours to a user or system user (ring group, queue, IVR) is to create another department and set the office hours there?
To put it another way, is it possible to override department office hours at user or system user level?
Users can have their own office hours defined, independent of their department
System Extensions will follow the department's office hours, to which they are assigned.
It is possible to override the office hours for a department if you want
Select your department, and the behaviour you want
Reactions: IrinaP_3CX
Thank you very much for the very comprehensive answer - much appreciated.:)
Reactions: NicholasP_3CX
tom.walker@blackcountryra
