v20 Split DNS
RichB
SOHO User
Please can someone confirm if the IP entries of LAN IP Phones such as these below will change to DNS entries or will they remain the same?
They'll move to FQDN which is why the need for split DNS is a must. There will be no In or Out of office anymore.
Yes that's what I thought, creates work but not the end of the world, I have options available.
We use Vultr already for the 3cx installs and a SBC. I do not believe we are using anything local. Maybe someone on here has a similar setup? All the webclients use the FQDN already to log in and the IP phones do have local IPs but maybe they are already set properly?
Split DNS is for local installs
Reactions: Charles_3CX
Or cloud installs connected via Site2Site VPN.
So essentially since i really dont have a local install that is not affecting my sites.
Reactions: NatalyS_3CX
Correct - if everything is using FQDN already (or IP to the SBC itself and the SBC is using FQDN), then you don't have to worry.
Jake_Southern
