v20 Store app - primary device?
Alphabetic
3CX MVP
I'm trying to call a number from the app and instead of off-hooking my desk phone it just uses the softphone.
where does one set the primary device now?
Hi there.
Are you referring to uaCSTA support where you can control your deskphone from the app?
probably. For now im back to using the PWA as this allows me to manipulate the desk phone.
Hi Team
uaCSTA is currently being discussed. It should be available shortly. Don't worry - bear with us a little while longer.
Reactions: OlegR_3CX
BillyAkansel
