v20 supported network configurations - multi NIC
arupper
Dear all
I'm planning to upgrade my enterprise on prem setup to v20.
Currently we're running in a complicated segregated network scenario, we have successfully used v18 with two network interfaces, following the official guideline (date: 2012; 3cx Blog) on what is supported.
Now with v20, there is a need for Split-DNS, I'd like to know if the scenarios in the blog post mentionned above are still valid and in particular if I still can utilize two NICs, even with Split-DNS.
Otherwise I'd need to implement a specific firewall scenario which makes things really complicated.
Thanks!
Hi there.
The logic of using multiple NICs is the same, and it should be a default gateway only on a single one, however the Split DNS should be used in your case too.
Thanks, Oleg. I'll try this in the next month.
You are welcome.
Feel free to let us know about the outcome and put your feedback here.
ARKC
