V20 U10 Extending Our AI Lead: Improved Agents, MCP, and Local Transcription on a Mac
You updated 3CX in the last ~20 hours or so? (not sure of the exact release time of that kernel, but prior to that it won't be installed)
Of our Debian 12 (non-3CX) VMs not all had the symptom by this morning so it's unclear to me what triggers it, nor why it takes a few minutes to many hours to occur.
i did my 3cx VM on-prem this morning. All 3 separatel U10, 3cx Ai, and then the Debian Security.
If you wait long enough I expect you’ll see it…
If you have ssh [edit: or console] access you can run uname -r to see your running kernel version, though.
We do what 3cx has in console. Our current kernel after this mornings u10, 3cxAi, and Debian updates direct thru 3cx console is: 6.1.0-54-amd64. And appears the -55 is the issue kernel. So this seems to be with users using the non 3cx Debian build and are on -55.
Reactions: SteveITS
Im not finished with my analysis yet, but its looking like it depends on whether the lightsail instances uses 3cx repos or debian repos. That seems to possibly depend on when the system was installed and what version of 3cx was initially installed on it. This is a working theory right now. It would explain why some lightsail instnaces are affected and others arent.
This is one reason we stick within 3cx repos and their approved/tested updates. Also, having a LAB system to test these patches on before doing in a production environment.
Admin Console restrictions appear to limit MCP tool functionality when using external tools such as ChatGPT/Codex. Is there any way to work around that?
