V20 U7 Final: 3CX System Management for Admins Gets Major Boost
Hotfix to 3CX v20 u7 1060 without change log entry?
if i remember correctly, i read something on the forum quite a few months ago that it would be a hard requirement to offload this data later into the V20 existence. can i find that thread now? no... sorry. but I swear I read it.
we already push our backups offsite (even on cloud systems) for each client, so this was as simple as checking 4 additional boxes on each system over the course of a couple hours and we're good to go.
How did you bill for the extra expense?
our most expensive customer only costs us 75 cents a month for a google storage bucket. we don't even charge them the 75 cents.
most of the others are 25 cents a month or less.
its crazy how cheap storage is with Google cloud
  • Love
Reactions: Colorado VoIP
Another question related to the updates.
I know automatic updates can not be disabled for our 3CX hosted.
But the updates are being applied when our call centre is active and waiting for calls. which is 10 PM in the evening.
Can the update process be changed to 03 AM or 04 AM to be safer for the system?
This update time is conflicting with our precious customers who need help urgently by calling us.
Settings are not enabled in the updates menu:
Hi there,
Since updating to this version (and subsequently the hotfix), the filtering function in the call log doesn't appear to work properly. The drop-down for call status doesn't seem to change the results. Regardless of what it is set to, I only get 'all' calls rather than the filtered 'only answered' or 'only unanswered'.
Hi there,
Filtering seems to work for me, try clearing your browser cache
Reactions: KyriacosS_3CX
I just found "Active Connections" on the dashboard from a previous upgrade. lol
Very handy. :)
The new alert system for high memory use - how long before triggering? If the PBX is at 91% memory for ___ seconds, it triggers - looking for that value.
Hog the memory with some random script to test :)
It should be between 2 to 4 minutes.
Reactions: SweetAction
Yes, two consecutive measurings exceeding the threshold - 2x2 minutes = 4
Loving the updates coming thick and fast. Slightly disappointed with U7 and the AWS integration. I had my hopes up that this would be S3 compatible buckets as well for other providers. Unless I am mistaken, it would just be a case of adding a URL option in the setup screen. Hate having to use the current backup options and refuse to use AWS.
Guess we will just have to stick with what we have for now
Reactions: Evolute IT and N_G
stauag
