V20, Update 3 Makes it to Release Candidate
Standard License = Free License.
That might be related to this issue ?
@NicholasP_3CX
( not good idea publish your license key in public forum )
No, also the free version is getting the final update.
Yes, the licence key should be blurred.
@Dragan Djurdjevic on your network do you use a proxy server or firewall that inspects all traffic for antimalware etc?
@NicholasP_3CX
Yes, it is test environment, but problem is the same in production as well.
Ok, thats infos we need to help. First you need to access your pbx by fqdn. Did the firewallcheck pass?
If I access by FQDN issue is the same. Firewall check is passed
And you should check your firewall regarding proxy, ssl inspection and so on.
In test environment we have firewall but without deep inspection. We passed Aplha, Beta 1 and Beta 2 and we blocked now. Otherwise in V18 we did not have any issue with update.
Unless the system was modified in some unexpected way, or the 3CX update manifest is being cached by a proxy, you should not really be seeing the older versions.
You can also get help from your 3CX Partner to investigate and see if any critical files were changed.
Can we confirm root cause of problem? Is there procedure to restore 3cx to previous version?
In the support info package @Dragan Djurdjevic sent me, I see the following :
The public IP address keeps changing.
22935ErrorSystem Manager5002610/15/2024 12:05:04 PMThe following error occurred when trying to send an email with subject ‘3CX Notification: Stopped Services - **.3cx.school’ to ‘***@gmail.com’ :
535: 5.7.0 Denied
22936InfoSystem Manager1002610/15/2024 1:03:58 PMYour public IP has changed and 3CX updated your FQDN records from 109.165.***.** to 188.246.**.***.
22937ErrorSystem Manager5002610/15/2024 1:04:00 PMThe following error occurred when trying to send an email with subject ‘3CX Notification: Change in your Public IP Address - ***.3cx.school’ to ‘**@gmail.com’ :
535: 5.7.0 Denied
22938InfoSystem Manager1002610/15/2024 2:23:58 PMYour public IP has changed and 3CX updated your FQDN records from 188.246.**.*** to 109.165.***.**.
22939InfoSystem Manager1002610/15/2024 3:03:59 PMYour public IP has changed and 3CX updated your FQDN records from 109.165.***.** to 188.246.**.***.
22940ErrorSystem Manager5002610/15/2024 3:04:00 PMThe following error occurred when trying to send an email with subject ‘3CX Notification: Change in your Public IP Address - ***.3cx.school’ to ‘***@gmail.com’ :
535: 5.7.0 Denied
22941InfoSystem Manager1002610/15/2024 3:43:58 PMYour public IP has changed and 3CX updated your FQDN records from 188.246.**.*** to 109.165.***.**.
22942InfoSystem Manager1002610/15/2024 5:03:58 PMYour public IP has changed and 3CX updated your FQDN records from 109.165.***.** to 188.246.**.***.
22943ErrorSystem Manager5002610/15/2024 5:04:01 PMThe following error occurred when trying to send an email with subject ‘3CX Notification: Change in your Public IP Address - ***.3cx.school’ to ‘***@gmail.com’ :
535: 5.7.0 Denied
22944InfoSystem Manager1002610/15/2024 6:23:58 PMYour public IP has changed and 3CX updated your FQDN records from 188.246.**.*** to 109.165.***.**.
22945InfoSystem Manager1002610/15/2024 9:03:59 PMYour public IP has changed and 3CX updated your FQDN records from 109.165.***.** to 188.246.**.***.
22946ErrorSystem Manager5002610/15/2024 9:04:01 PMThe following error occurred when trying to send an email with subject ‘3CX Notification: Change in your Public IP Address - ***.3cx.school’ to ‘***@gmail.com’ :
535: 5.7.0 Denied
22947InfoSystem Manager1002510/15/2024 10:04:09 PM3CX logs and temporary files were deleted to conserve disk space.
22948InfoSystem Manager1002610/16/2024 2:23:59 AMYour public IP has changed and 3CX updated your FQDN records from 188.246.**.**** to 109.165.***.**.
22949ErrorSystem Manager5002610/16/2024 2:24:00 AMThe following error occurred when trying to send an email with subject ‘3CX Notification: Change in your Public IP Address - ****.3cx.school’ to ‘*****@gmail.com’ :
535: 5.7.0 Denied
22950InfoSystem Manager1002610/16/2024 3:04:01 AMYour public IP has changed and 3CX updated your FQDN records from 109.165.***.** to 188.246.**.***.
22951InfoSystem Manager1002610/16/2024 3:44:00 AMYour public IP has changed and 3CX updated your FQDN records from 188.246.**.*** to 109.165.***.**.
22952InfoSystem Manager1002610/16/2024 4:24:01 AMYour public IP has changed and 3CX updated your FQDN records from 109.165.***.** to 188.246.**.***.
22953InfoSystem Manager1002610/16/2024 5:44:01 AMYour public IP has changed and 3CX updated your FQDN records from 188.246.**.*** to 109.165.***.**.
22954InfoSystem Manager1002610/16/2024 6:24:00 AMYour public IP has changed and 3CX updated your FQDN records from 109.165.***.** to 188.246.**.***.
22955InfoSIP Server409810/16/2024 6:30:55 AMService got signal to stop: 15
22956InfoSIP Server409810/16/2024 6:30:55 AMService got signal to stop: stop service
22958InfoSIP Server409710/16/2024 6:31:14 AMService started
Additionally,
The nginx file appears to have been modified.
Additionally,
Yes, we have no fix public IP address. IP address is changed periodically by ISP.
Can you help me to solve problem?
I see a local IP address in the logs instead of the public IP address. ( 192.168.76.1 )
2024/10/16 08:32:13.523|0039|Info| [Http] -192.168.76.1 GET https://192.168.215.60:5001/xapi/v1/GetUpdates() - 200 7301 application/json;+charset=utf-8;+odata.metadata=minimal;+odata.streaming=true 4170.3388ms
2024/10/16 08:32:13.598|0039|Info| [Http] +192.168.76.1 GET https://192.168.215.60:5001/xapi/v1/GetUpdatesStats() - - -
2024/10/16 08:32:13.607|0039|Info| [Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker] Route matched with {action = "GetUpdatesStats", controller = "Updates"}. Executing controller action with signature XAPI.Models.Updates.XUpdatesStats GetUpdatesStats(System.Threading.CancellationToken) on controller XAPI.UpdatesController (XAPI).
2024/10/16 08:32:13.683|0039|Info| [Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker] Executed action XAPI.UpdatesController.GetUpdatesStats (XAPI) in 75.8558ms
2024/10/16 08:32:13.685|0039|Info| [Http] -192.168.76.1 GET https://192.168.215.60:5001/xapi/v1/GetUpdatesStats() - 200 146 application/json;+charset=utf-8;+odata.metadata=minimal;+odata.streaming=true 86.2302ms
2024/10/16 08:32:14.649|0004|Debg| [Quartz.Core.QuartzSchedulerThread] Batch acquisition of 0 triggers
2024/10/16 08:32:22.578|0037|Info| [Http] +192.168.76.1 GET https://192.168.215.60:5001/xapi/v1...Calls,IpV4,NetworkPorts,HasNotRunningServices - - -
2024/10/16 08:32:22.584|0034|Info| [Http] +192.168.76.1 GET https://192.168.215.60:5001/xapi/v1...rror'&$count=true&$orderby=TimeGenerated desc - - -
2024/10/16 08:32:22.600|0034|Info| [Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker] Route matched with {action = "Get", controller = "EventLogs"}. Executing controller action with signature Microsoft.AspNetCore.Mvc.IActionResult Get() on controller XAPI.EventLogsController (XAPI).
2024/10/16 08:32:22.610|0037|Info| [Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker] Route matched with {action = "Get", controller = "LicenseStatus"}. Executing controller action with signature Microsoft.AspNetCore.Mvc.IActionResult Get() on controller XAPI.LicenseStatusController (XAPI).
2024/10/16 08:32:22.841|0037|Info| [Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker] Executed action XAPI.LicenseStatusController.Get (XAPI) in 230.8789ms
2024/10/16 08:32:22.844|0037|Info| [Http] -192.168.76.1 GET https://192.168.215.60:5001/xapi/v1...Calls,IpV4,NetworkPorts,HasNotRunningServices - 200 686 application/json;+charset=utf-8;+odata.metadata=minimal;+odata.streaming=true 265.3923ms
The requests are taking a long time to resolve. This suggests network or routing issues.
We can also see that the server has two local IP addresses:
ens18: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.215.60 netmask 255.255.255.0 broadcast 192.168.215.255
inet6 ****::****:b3ff:****:**** prefixlen 64 scopeid 0x20<link>
ether **:**:**:**:**:**txqueuelen 1000 (Ethernet)
RX packets 91653 bytes 76387910 (72.8 MiB)
RX errors 0 dropped 33359 overruns 0 frame 0
TX packets 27963 bytes 13248608 (12.6 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
ens19: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.100.3 netmask 255.255.255.0 broadcast 192.168.100.255
inet6 ****::****:****:****:**** prefixlen 64 scopeid 0x20<link>
ether **:**:**:**:**:** txqueuelen 1000 (Ethernet)
RX packets 33364 bytes 2135866 (2.0 MiB)
RX errors 0 dropped 29 overruns 0 frame 0
TX packets 52 bytes 3944 (3.8 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 1565755 bytes 237656743 (226.6 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 1565755 bytes 237656743 (226.6 MiB)
And I see multiple local IP addresses on the same PBX.
I also notice IPv6 addresses, but 3CX doesn't seem to detect them (in the screenshot of your Dashboard, IPv6 shows as N/A).
2 local IP addresses are fine; we are using both of them. We do not use IPv6
This is not an IP replacement by the ISP.
There are two public IPs that keep switching constantly, as if you have two internet connections.
Are you configured in Load Balancer mode?
Telekom Srpske and Blicnet d.o.o. Banja Luka.
Yes, we have SD-WAN and use both providers.
The simplest solution:
Switch to the Cloud,
or back up your PBX, create a new VM, and restore your backup.
Avoid having two local IPs. Start by running your PBX with a single local IP.
Be sure to follow the network configuration recommendations.
I see in the Support Info that the Firewall Checker failed, which is not a good sign.
To configure a policy to ensure that 3CX is not affected by the SD-WAN, you can set up a specific routing or traffic policy on your SD-WAN appliance to bypass SD-WAN for all 3CX-related traffic. Here’s a general approach you can follow:
Ensure that your router configuration follows 3CX's guidelines.
Firewall & Router Configuration Help​
These apply to on-premise installs only!
Can we update 3cx using SSH commands?
No, This is not recommended... trying to bypass a problem with manual operations only delays it and allows it to worsen over time.
It is not issue with firewall, because even I disable one ISP provider and firewall check would be passed, issue is the same.
jasonkkrause
