- Joined
- Aug 14, 2014
- Messages
- 100
- Reaction score
- 0
Can someone explain the organization domain. As far as I can tell this is how Elastix will be able to separate out multi-tenant traffic. What I am wondering is if it needs to be public top level domain (ie. .com, .org, etc.) or can it just be internal local TLD (ie. .local). Right now the GUI only allows public TLD. Does it need to be resolvable or can I cheat by using IP for domain setting and the organization domain for proxy setting on the phone. That is how I do it with Kazoo.
Also would like to know how Kamailio plays into this. I'm guessing this is primarily the reason Kamilio is needed.
Can the multi-tenant be disabled or are there any plans to add that feature? Eliminating the need for an Organization and presumably Kamailio.
