VAD v14 - Help
uros3n
Hello All,
I've found myself in a bit of a pickle. I've somehow lost the 3CX Voice Application Designer v14 install file.
I'd like to download it, but I can't do it on official download link. And I really need it.
Would any of you by any chance have the aforementioned install file in your posession and would be kind enough to share it?
One virtual coffee invitation is awaiting the brave soul.
Toodle pip,
Uros
Hello @uros3n
I would recommend updating to the latest stable version of 3CX and use the latest Call flow designer of V15.5. You need to upgrade as older versions of the PBX are no longer able to authenticate against the activation server due to a certification change so if your installation tries to activate it will fail and will revert to the free version.
Hello Yiannish_3CX,
Thank you for the information.
I'm well aware the upgrade is the best way to move forward. The v15.5 PBX is already undergoing testing and will be in use shortly.
Unfortunately, there are updates I need to do to VADs on the v14 PBX.
I would be quite grateful if anyone would be able to share the Voice Application Designer installer.
Best regards,
Uros
jmarshall
