Video's on screen sharing
Brutis
When we share a video when screen sharing it is very soft
What can the problem be ?
Regards
Bertus
Video is generally a bit soft because its compressed, but you can try and increase the "Meeting Quality" setting (as an Organizer) and move it up to "Quality" instead of "Balanced" provided there is enough bandwidth
I tried that but it is still the same. We tried videos that is on our laptops and youtube from the web. but still the same. But if I take 1 of my 3CX recordings it is loud enough
Regards
can you provide a screenshot as an example? I just want to see how soft the video is
Please see attached a small piece of the sound when we are sharing. this was the loudest i can get any sound we share
Hi Brutis,
Audio sounds like this because Auto Gain Control, Echo Canecellation and Noise Reduction is applied to each participant's audio stream. If you want the full original sound quality, you'll need to go to your meeting settings and disable these 3 options.
Thanks . For me as a main organizer of the "Meeting" it is loud on the other side but if someone else that I made a organizer plays something I still can't hear them. Even their settings are the same as mine ? what can that be ?
Hi Brutis,
Hi Thanks for the help.
It is still not resolved still have issues with this .
Regards
Bertus
Hi Brutis,
How are you sharing the audio of a youtube video when you're screen sharing? Are you switching your input device to a virtual microphone?
Hi Brutis,
We actually tried videos as mentioned before that is on my pc as well.
No we didn't change any mic input when screen sharing
Regards
How are you sharing the audio of a shared video then? It's important to know this in order to be able to answer your question at least about the audio quality.
