Visibility of calls in webclient
Kristof Beckers
We are implementing the use of the webclient more and more.
I did get a question though from Mamanagent.
When somebody makes a call, other people can see in the webclient to who they are calling, internally and externally. it is only on the local pbx, we don't see it from the remote pbx systems.
Is it possible to block this on the local pbx to, because of privacy issues some people don't want just anyone to see which numbers are calling certain people.
This al;l has to do with permissions of the group. Try making sure that "Can see group calls" is not enabled (if memory serves)
There are also individual rights under each extension so you can disable users to see group calls while some others might want to be able to see group calls.
Zexus
