Voice prompt at the end of long voice mail capability
Wendell Urth
Hi all,
I need to extend the voicemail duration to 15 minutes and i have read other posts describing how this might be done, so it shouldn't be a problem. However i also need to provide a warning at the end of this period, letting the user know that the recording time is finishing. Is this at all possible?
I have had this implemented on a custom asterisk solution, but unsure as to whether it is possible using 3cx. For clarity it would look like the following:
Call -> Straight to voicemail - > Voicemail greeting - > ........ 15mins max recording time .... - > Warning prompt at 14 mins 45. Recording ends at 15 mins.
Many thanks for your help!
W
Hello @Wendell Urth
You can change the voicemail duration by following this guide: https://www.3cx.com/blog/docs/maximum-duration-voicemail/
Unfortunately you cannot set a prompt to play during a voicemail recording in 3CX. I would recommend posting this as a feature request to our ideas section of the forum https://www.3cx.com/community/forums/3cx-ideas/ . All posts are reviewed by their corresponding Departments and, if feasible and voted for by other users as well, may be implemented in an upcoming service pack or update.
Thanks YiannisH, thats perfectly clear. Appreciate the help
W
Glad i could assist
zipman
