VoiceFlex Outgoing Call Issue
markcronin
Trainee Partner
Hey All,
This has really got me stuck... Added VoiceFlex SIP Trunks today.. Incoming calls working fine... Default Outbound rule for all default extensions, however outbound calls fail... Logs below...
I have removed actual numbers, DNS Names and IP's with x - Any help/suggestions would be hugely appreciated :)
04/21/2020 7:05:41 PM - Leg L:59.1[Extn:300] is terminated: Cause: BYE from PBX
04/21/2020 7:05:41 PM - Terminated from "Mark Cronin"<sip:[email protected]>;tag=6tssy5JfzcFTekgmBVsAQmO0GPpOWwo8 to <sip:[email protected];tag3cx=7yf4paps>;tag=7e262658; reason: Rejected
04/21/2020 7:05:41 PM - L:59.1[Extn:300] Sending: OnSendResp Send 404/INVITE from 0.0.0.0:0 tid=PjR3ftHmqwht.rR2M9.D436qFIcDhYEwho Call-ID=yWblyIxzXhv7m7duSReQ2pn9LJREZ-vl:
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---PjR3ftHmqwht.rR2M9.D436qFIcDhYEwho;rport=5080
Via: SIP/2.0/UDP [::ffff:188.29.165.107]:12105;branch=z9hG4bK-524287-1---tunneltid;rport;tnlid=clnt.1-lyiuuqaaamscc3-syih-e9pkiltixmss_55480287
Via: SIP/2.0/TCP 127.0.0.1:50195;rport;branch=z9hG4bKPjR3ftHmqwht.rR2M9.D436qFIcDhYEwho;alias
To: <sip:[email protected];tag3cx=7yf4paps>;tag=7e262658
From: "Mark Cronin"<sip:[email protected]>;tag=6tssy5JfzcFTekgmBVsAQmO0GPpOWwo8
Call-ID: yWblyIxzXhv7m7duSReQ2pn9LJREZ-vl
CSeq: 9156 INVITE
Warning: 499 msc-internal-3cx.e4atkokn5voebebn4jagklxg5g.zx.internal.cloudapp.net "Not found"
Content-Length: 0
04/21/2020 7:05:41 PM - SendMsg from <sip:[email protected];tag3cx=7yf4paps>;tag=7e262658 to "Mark Cronin"<sip:[email protected]>;tag=6tssy5JfzcFTekgmBVsAQmO0GPpOWwo8
04/21/2020 7:05:41 PM - Leg L:59.2[Line:10000>>01429xxxxxx] is terminated: Cause: 404 Not Found/INVITE from 93.95.124.78:5060
04/21/2020 7:05:41 PM - L:59.2[Line:10000>>01429xxxxxx] got Terminated Recv 404/INVITE from 93.95.124.78:5060 tid=5608244aeb6e8535 Call-ID=hDKKi42V4qwO27hNRQwJCg..:
Via: SIP/2.0/UDP 10.0.0.5:5060;branch=z9hG4bK-524287-1---5608244aeb6e8535;received=51.145.xx.xxx;rport=5060
To: <sip:[email protected]:5060>;tag=as7909e58f
From: "Mark Cronin"<sip:[email protected]:5060>;tag=4c50ae00
Call-ID: hDKKi42V4qwO27hNRQwJCg..
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Server: Voiceflex
Supported: replaces, timer
Content-Length: 0
04/21/2020 7:05:41 PM - Terminated from <sip:[email protected]:5060>;tag=as7909e58f to "Mark Cronin"<sip:[email protected]:5060>;tag=4c50ae00; reason: Error
04/21/2020 7:05:41 PM - ~Target=Unknown:01429xxxxxx@(Ln.10000@Voiceflex)
04/21/2020 7:05:41 PM - Call(C:59) is terminated
04/21/2020 7:05:41 PM - [CM503020]: Call(C:59): Normal call termination. Call originator: Extn:300. Reason: Not found
04/21/2020 7:05:41 PM - [CM503016]: Call(C:59): Attempt to reach <sip:[email protected]:0> from Extn:300 has failed. Reason: Not Found
04/21/2020 7:05:41 PM - [Flow] Current call diversion path:[]
04/21/2020 7:05:41 PM - L:59.1[Extn:300] failed to reach Line:10000>>01429xxxxxx, reason Not Found
04/21/2020 7:05:41 PM - RerouteReq
04/21/2020 7:05:41 PM - Call to T:Line:10000>>01429xxxxxx@[Dev:sip:[email protected]:5060] from L:59.1[Extn:300] failed, cause: Cause: 404 Not Found/INVITE from 93.95.124.78:5060
04/21/2020 7:05:41 PM - L:59.2[Line:10000>>01429xxxxxx] got Failure: Failure Recv 404/INVITE from 93.95.124.78:5060 tid=5608244aeb6e8535 Call-ID=hDKKi42V4qwO27hNRQwJCg..:
CSeq: 1 INVITE
Server: Voiceflex
Content-Length: 0
04/21/2020 7:05:41 PM - [CM503003]: Call(C:59): Call to <sip:[email protected]:5060> has failed; Cause: 404 Not Found/INVITE from 93.95.124.78:5060
04/21/2020 7:05:41 PM - Session 5696 has failed in leg L:59.2[Line:10000>>01429xxxxxx] ; Cause: 404 Not Found/INVITE from 93.95.124.78:5060
04/21/2020 7:05:41 PM - Failure from <sip:[email protected]:5060>;tag=as7909e58f to "Mark Cronin"<sip:[email protected]:5060>;tag=4c50ae00
04/21/2020 7:05:41 PM - [CM503025]: Call(C:59): Calling T:Line:10000>>01429xxxxxx@[Dev:sip:[email protected]:5060] for L:59.1[Extn:300]
04/21/2020 7:05:41 PM - Route to L:59.2[Line:10000>>01429xxxxxx] sends Invite-OUT Send Req INVITE from 93.95.124.78:5060 tid=5608244aeb6e8535 Call-ID=hDKKi42V4qwO27hNRQwJCg..:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---5608244aeb6e8535;rport
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
Content-Type: application/sdp
User-Agent: 3CXPhoneSystem 16.0.4.504 (504)
Content-Length: 289
v=0
o=3cxPS 9379100506456064 12248356210343937 IN IP4 51.145.xx.xxx
s=3cxPS Audio call
c=IN IP4 51.145.xx.xxx
t=0 0
m=audio 9100 RTP/AVP 0 8 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=sendrecv
04/21/2020 7:05:41 PM - Outbound CID reformat rule for DN:10000 is disabled (<Rules />)
04/21/2020 7:05:41 PM - Dev(1030529782):[sip:[email protected]:5060 / 10000]: PBX contact is public IP: <sip:[email protected]:5060/UDP>
04/21/2020 7:05:41 PM - SLA is globally disabled
04/21/2020 7:05:41 PM - Added leg L:59.2[Line:10000>>01429xxxxxx]
04/21/2020 7:05:40 PM - [Flow] Call(C:59): making call from L:59.1[Extn:300] to T:Line:10000>>01429xxxxxx@[Dev:sip:[email protected]:5060]
04/21/2020 7:05:40 PM - [CM503027]: Call(C:59): From: Extn:300 ("Mark Cronin" <sip:[email protected]:0>) to T:Line:10000>>01429xxxxxx@[Dev:sip:[email protected]:5060]
04/21/2020 7:05:40 PM - [CM503004]: Call(C:59): Route 1: from L:59.1[Extn:300] to T:Line:10000>>01429xxxxxx@[Dev:sip:[email protected]:5060]
04/21/2020 7:05:40 PM - Outbound CID reformat rule for DN:10000 is disabled (<Rules />)
04/21/2020 7:05:40 PM - Line limit check: Current # of calls for line Lc:10000(@Voiceflex[<sip:[email protected]:5060/UDP>]) is 0; limit is 10
04/21/2020 7:05:40 PM - Call(C:59): Call from Extn:300 to 01429xxxxxx matches outbound rule 'Outbound Rule'
04/21/2020 7:05:40 PM - [Flow] Call(C:59): has built target endpoint: Out#:>>Rule{Outbound Rule}>>01429xxxxxx for call from L:59.1[Extn:300]
04/21/2020 7:05:40 PM - [Flow] Target endpoint for 01429xxxxxx is Out#:>>Rule{Outbound Rule}>>01429xxxxxx
04/21/2020 7:05:40 PM - Looking for outbound rule: dialed = [01429xxxxxx], processed: [01429xxxxxx]; from-ext:
04/21/2020 7:05:40 PM - [Flow] Building target endpoint to 01429xxxxxx from "Mark Cronin" <sip:[email protected]:0>
04/21/2020 7:05:40 PM - [CM503010]: Call(C:59): Making route(s) from Extn:300 to <sip:[email protected]:0/UDP>
04/21/2020 7:05:40 PM - Remote SDP is set for leg L:59.1[Extn:300]
04/21/2020 7:05:40 PM - [CM505001]: Endpoint Extn:300: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent:
Bluebox Global
