Voicemail Callflow is too complicated, Recording without entering "0"
3cxisti
if a call is forwarded to the VMail, some further keys are currently necessary to save the recroding the exit the menü. This is way too complicated for our client.
Is there any way to allow the recording without any or only with one key (like #)?
Thank you for your help.
Best regards,
I
(we use the hosted version of 15.5.15502.6)
Hanging up will save the recording as it does with pretty much any voicemail system.
Hello @3cxisti
As @cobaltit mentioned terminating the call after leaving a message will save the voicemail. You can modify the prompt to account for this.
zipman
