Solved Voicemail Disabled
Tarheels
Platinum Partner
All of my extensions are giving a voicemail is disabled message but the voicemail is enabled
Did this happen after...an upgrade, or some other change? Are you able to dial the VM number, and retrieve messages for an extension?
Do you have an voice mail account assigned - Settings - Voicemail Settings. Normally 666
On 3CX dashboard - in the pabx status does system status have a green tick. If not if you click on system extensions, you maybe able to work out the issue
The problem was that the customer had maxed out the storage on the 3cx. Once I changed the voicemail settings to delete messages older than 30 days it opened up storage.
Unfortunately, a lot of people simply do not delete messages. In some cases, they do need to be kept (possible legal reasons?), but most users just can't be bothered.
Setup email alert on recordings. so if the recordings meets a specified percentage of the allowed storage -recordings - quota
Also setup email alert when the storage is getting low - settings - email - notifications
Reactions: CentrexJ
GP Concepts
