Voicemail - Eliminate having to press * key to delete voicemail.
kjacques1
Is there a setting to eliminate having to press the * key to confirm deleting a voicemail? It get's a little redundant if you have a bunch of voicemails to delete.
Have never seen anything about doing this differently. It's a way to prevent the unintended deletion of voice mails. It's no different than the confirmation required when emptying the Recycle Bin on your computer (or many other similar computer functions). When it's gone, it's gone.
Given the fact that the voicemail is already delivered via email, I really don't need to confirm that I want to delete it on the phone. I would really like the option to disable it altogether.
RicoDinero
