Voicemail to email wrong display name
Tom Lee
Good morning,
We are using the "3CX SMTP server" to send emails. The voicemail to emails we received are with From: "3CX Communication System - Tom Lee" and in the email header, the display from is From: 3CX Communications System - Tom Lee <[email protected]>
I looked at the VoiceMail template, the From (Display Name) is %%CALLER%%
Does anyone know how to change the voicemail senders to "3CX Communication System" and From: 3CX Communications System <[email protected]>
Tom
Good morning,
Tom
Those lines are added when using 3CX SMTP, nothing you can do to change it.
If you want that control you will need to use your own SMTP.
sherry reynolds
