Voip Innovations Export
JLink Communications
I see now that VI is no longer supported in 3CX and I understand the reasons stated in other forums.
I'm curious if anyone has exported it from working 3CX servers and imported to new servers to get around it for now? Or did you go back to creating 5-8 different trunks?
Huh? Why would you need to create 5-8 different trunks? The trunk settings haven't changed, 3CX just no longer provides a template. Just export or worst case scenario take screenshots or otherwise document a working configuration. I would imagine Voip Innovations likely has a configuration guide as well
Support99
