Solved Voip Innovations Gone in Beta 16.0.5.389
Yourphonetech
What happened to the Voip Innovations template with Beta 16.0.5.389. It is no longer there???
Yes it was removed. My assumption is the are no longer considered a 3CX supported provider. This is probably due to the acquisition by Sangoma.
The change log states the removal and cobaltit has given a very good reason why this might be the case.
Agreed. And you heard it directly from the man who knows. Hey Stefan!
Stefan, Thank you for the follow up.
Kayla Norris
